Old Feb 23, 2013 | 11:04 AM
onehundred80
Default Re: help crossfire speed sensor switch
Originally Posted by nashcrossfire
hey people's. im back.
ok so I changed the condutor plate and got the yellow plug also a new gasket and new atf and had thrm fitted.today the mechanic said that the car still the same. im so pissed right now.
he said the car knocks in to drive and still not changing gear.but he rang me yesterday and said that the bottom of my car was drenched in oil.which must of been the old gasket.
so where is the turbine speed sensor on the crossfire?
anyone got a part number please and even a picture.it can only be that right or?
If you look at the picture in this post (click) you will see the parts that can cause the problem. The problem is called 'limp mode', the transmission stays in second gear only so as not to cause damage to itself.
The part consists of two parts screwed together, the electrical plate and the solenoid plate. Which part was replaced or were both replaced?
