Old Feb 24, 2013 | 02:03 PM
onehundred80
Default Re: Crossfire Electric issues/Garage recommend Please - South Wales?
Originally Posted by jtaylortech3
Ok, well the issues I am having is that recently 3 warning lights came on which are the abs, bas esp and the handbrake light. They all come on at the same time and generally shortly after the light comes on the car won't move much if you press the accelerator (I would describe it as if your stuck in lower gear in a manual car). If I stop the car, turn the engine on and off, then try to go again all the light go off and it can drive for a while before the same issues happen again. Its a very strange thing and when its not doing these issues, it seems to drive perfect with no issue I could think of at all....
Hope that helps. Thanks
You need the fault codes read, the dash lights do not flash to tell you the troubles. You need to use an OBDll scanner. With the codes we can tell you the problem solution most likely.
