Here are all the measurements. Thanks for the great install instructions with the trim. Extremely easy!
Andrew, what is the possibility of getting a sticker that is the negative of the letters (leaves everything blacked out except the letters) letting the light show through CROSSFIRE? Also if the sticky stuff is on the face of the letters it can be stuck to the inside of the glass of the back hatch and the third LED housing will bolt right up against it. I would REALLY like the sticker this way if possible. The sticker would then be a little larger since the glass is at a angle instead of the very skinny third brack light which will be really hard to install and not have as neat of an effect like up against the glass.
The LED plastic housing is 7/16" in height and 11 13/16" in length.
The glass opening is 1 7/8" in height and 11 5/8" in length.
