Fun with decals on the third brake light.
Old Feb 16, 2013 | 09:39 AM
  #81 (permalink)
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: Fun with decals on the third brake light.
Originally Posted by andrew
~ i will contact the supplier and see if they offer something with less adhesion ... they might think thats a strange question but i will explain why.
~ i spoke with the graphic company and they don't offer anything with less adhesion.
Old Feb 16, 2013 | 03:03 PM
  #82 (permalink)
Larry Hitze's Avatar
Andrew, I recieved the letters the other day. These can't be the coupe stickers for the 3rd brake light can they? Here it is next to the lit up 3rd brake light.
Old Feb 16, 2013 | 08:07 PM
  #83 (permalink)
andrew's Avatar
Red face Re: Fun with decals on the third brake light.
~ opps ... you received the roadster by error. i will resend you the coupe design on monday ... sorry for the mix up.
Old Feb 16, 2013 | 09:34 PM
  #84 (permalink)
No problem Andrew. If you don't mind just send a roadster instead ( red or blue ), I'll be just as happy! It will fit then.
Old Feb 26, 2013 | 08:58 AM
  #85 (permalink)
andrew's Avatar
~ it appears i was given the wrong measurements for the coupe size decal ... can one please give me the correct measurement so i can produce the right size and resend the corrected size to coupe buyers?
thanks,
andrew
Old Feb 26, 2013 | 10:29 AM
  #86 (permalink)
JesseJamessrt6's Avatar
Andrew that sucks, sorry to hear that. I will measure the light tonight and take a couple pics for comparison.
Old Feb 26, 2013 | 10:41 AM
  #87 (permalink)
thanks,
andrew
Andrew, it also seems you were supplied ( by me ) the correct measurement for the roadster light, but I found that when the decal is applied, I did not consider that the final 1.5" on each side is NOT lit.
So basically, I have R O S S F I R when brake light is lit.
My bad, so sorry.
Please correct before sending anyone else a roadster decal,
I don't deserve one due to my stupidity.
Old Feb 26, 2013 | 08:02 PM
  #88 (permalink)
Here are all the measurements. Thanks for the great install instructions with the trim. Extremely easy!
Andrew, what is the possibility of getting a sticker that is the negative of the letters (leaves everything blacked out except the letters) letting the light show through CROSSFIRE? Also if the sticky stuff is on the face of the letters it can be stuck to the inside of the glass of the back hatch and the third LED housing will bolt right up against it. I would REALLY like the sticker this way if possible. The sticker would then be a little larger since the glass is at a angle instead of the very skinny third brack light which will be really hard to install and not have as neat of an effect like up against the glass.
The LED plastic housing is 7/16" in height and 11 13/16" in length.
The glass opening is 1 7/8" in height and 11 5/8" in length.
Old Feb 26, 2013 | 08:17 PM
  #89 (permalink)
jsquare's Avatar
If you had rebadged your car just reattached to brake light and apply 5 coats of Plastic-dip (from Home Depot) and before it completely dries remove the letters. Worked perfect. Also had a yearly inspection done the next week with no problem.
Old Feb 26, 2013 | 09:33 PM
  #90 (permalink)
The only with the glass decal is that it might not look right from car height eye level from behind. I already bought a can of lens tint so either way is actually fine. I'm sure you have already lost your butt on this project, so tell me what you can do either way. I will purchase the new style.
Old Mar 4, 2013 | 10:13 PM
  #91 (permalink)
andrew's Avatar
~ jesse thank you for taking the time and sending the exact measurements ~ let me see what i do...
Valk
Jun 22, 2025 09:15 PM
RamblinShamblin
Aug 12, 2017 10:55 PM
8ighth Wonder
Dec 15, 2015 01:42 PM
ozkancab
Sep 25, 2015 10:55 AM
jaesa
Sep 7, 2015 01:50 PM
