818.crossfire
Also is there supposed to be an inlet for the ram air (correct name?) pieces that come from under the motor cover on both sides coming from the grille? Mine only had one on the right side looking at the vehicle?
There should be one on each side for the stock airbox. If you're missing one you'll be gulping in some hot under-hood air which isn't great. Won't cause damage but cold air is much better.
