Old Mar 1, 2013 | 12:11 AM
  #66 (permalink)
latemodel21's Avatar
latemodel21
Default Re: LateModel21's Pulley Saver Kit - Installed
Originally Posted by JesseJamessrt6
That sure is sharp. I wonder if there would be any belt slip on immediate let off of WOT like before? I have no slip after your pulley set up with the three including the altenator.
PM'd
Hi Jesse,
I am not anticipating an issue with this. The new (ribbed idler) pulley is 14mm smaller than the pulley you had in that position when you had a slipping issue ... and more to the point, your alternator's momentum has been reduced by MORE than 15% (by virtue of 15% slower speed AND slightly less rotating mass) AND it now has 15% more belt wrap.
Cheers,
Chris
