Re: latch on top partially locked
Was ist los?
Morons in Germany need a swift kick in the swastika. (again)
The access panels SHOULD be accessible while top is up!
Design error.
page 23-530 instructs to "partially remove top/cover to access the linkage assembly."
Image shows canvas peeled off, and top is up and latched.
Again if the header "access panels" would be accessible from inside the vehicle with top locked down, then adjustments Could be made to linkage...this is a BAD DESIGN.
Thanks alaxfire,
The set screw image has the guy using an allen wrench...really what size?
Manual is as poor as the design.
