Re: Where to buy 74mm Throttle Body Upgrade
The oem is still at your 68MM opening.. so defeats the idea for the most part if you don't at a wide open throttle.
If your just working on a limited funds upgrade.. add the TB.. trim the vanes out of the elbow.. add new gasket and reassemble.. the Maf housing can be done later with minimum work.
