Old Mar 8, 2013 | 03:42 PM
onehundred80
Default Re: Air Pump problems...Help!
Originally Posted by Spenzer4Hire
This afternoon I parked my car and went into a store for about 10 minutes. When I got back i heard the whirring sound of a shop vac coming from under my hood. I drove a couple of miles back to work and it was still running even when the engine was turned off. I located the part (air pump) but didn't know what it was. I quickly ran out to a local repair shop where they pulled the plug on it. It was crazy hot and smelled a little like burning, but it still appears to function. No CEL or anything abnormal.
After we plugged it back in and I started the car it's been functioning properly (i.e. shutting off when the car is off). Thoughts? If it's a failing relay, should I have it proactively replaced? I'm currently unplugging the air pump when I'm not driving, just in case it decides to start up and I'm not around to hear it.
Have a look at the relay for the air pump inside the RCM, if the contacts are burnt you could clean them up.Replacement of that relay would be a good idea if that is the problem.
I am assuming that you switched off the engine when you went into the shop.
There is a thread that shows the burnt contacts.
