Old Mar 13, 2013 | 01:21 PM
onehundred80
Default Re: 4 Eurocharged pulleys later and I'm still shredding belts. Help?
Originally Posted by latemodel21
Last month, I installed the new belt-wrap kit on God_Likes_Tebow's SRT-6
while doling so, I observed (and was inclined to compensate for with shims on the adjacent flanged pulley) that his 61mm EUROCHARGED pulley placed the belt a full .085" further forward of the motor than 4 SC pulleys I had on hand to compare it to. The 4 pulleys i compared it to were 3 factory SC pulleys and 1 of Rudy's "Karmen" pulleys (these were all essentially the same in this spec).
Now, I don't know if the deviation I observed (and measured) in this Eurocharged pulley is representive of the spec they are working with .... but it might explain your issue.
Chris
This is interesting, the pitch of the ribs on the belt are about .140", so if the ribs are out .085 then the tendency of the belt to want to jump is very strong. At the very least the ribs would get very hot and get destroyed.
It is critical that the back of the pulley bearing and the ribs keep the same dimensional relationship as the OEM pulley.
When copying the OEM pulley this relationship is vital.
Of course adding shims incorrectly will give the same result.
