Old Mar 14, 2013 | 05:05 PM
ala_xfire
Default Re: Top convertible problem
Manual top down for dummies :
1. release the D-ring and push the top up.
2. open trunk, turn the 5mm hex nut to release the window bow. close the trunk.
3. lift the window bow and use slim 10mm wrench or special tool to release tonneau latch.
4. lift the tonneau and hold it up.
5. fold the top GENTLY into the tonneau area.
6. close the tonneau and latch with the 10mm.
Manual top up :
1. lower the windows.
2. release and list tonneau.
3. lift the top and hold the rear bow up.
4. close & latch the tonneau.
5. close & latch the rear bow.
6. close and latch the D-ring.
HINT: If you hold the left front side of the top with your left hand and rotate it down slowly, it won't SLAM, then latch the D-ring.
( do this even when the top is working correctly )
