Old Mar 15, 2013 | 04:46 PM
johnlisa61's Avatar
johnlisa61
Default Re: Top convertible problem
Originally Posted by oledoc2u
I take it you bought the car with the broken top? Or did it leak fluid and you had the cylinders rebuilt?
I am with Dave on this one. You may have air in the system. I haven't had to work on mine but I would think you need to bleed the air out of the pump. Just my take if all the sensors are fine.
Thanks....I did find the leak...but also a little hydraulic fluid, did the trick... It's been up and down and filled the hydraulic fluid. So, I can no have the top down....and not worry too much.
Also.....another problem just surfaced.. The spoiler will not manually deploy and it was working before. I haven't touched anything related to that area or spoiler.. The dash indicator shows a red light when starting. If the red light lights? Is the fuse still good?? Just wondering. Also, is there a way to reset ??
Thanks to all who have helped.......It's been a good feeliing to be helped so feely.
John L
