Old Mar 19, 2013 | 04:45 PM
onehundred80
Default Re: Tire valve broken!?
Originally Posted by MyFire91
I just recently got my 05 Crossfire and the tire pressure light was on so i decided to go to my local gas station and fill them up with air. To my surprise, the tire valve on the front driver side seems to be broken and wont let me put air into it! it has some air in there but i want to fill it up to 32psi. it wont let me read the current psi and im afraid of driving like this. When i try to stick the air hose thing on there it only releases the current air inside the wheel already. What can i do!??
attached is a picture of the valve!
There is a part missing and the whole thing needs to be replaced. That is the Schrader valve showing and that is hidden by the broken part that is missing. Take the tire to a tire shop and get the top half of the tire pressure valve, it snaps onto the sending unit inside the tire. Keep the sending unit inside the tire or you will need to get the TPMS set which is more hassle.
If you got the car from a dealer get them to fix it.
