meh03
I recently installed a EC supercharger pulley. The instructions said to leave a .2-.3mm gap between the pulley and the supercharger. That's about the width of a couple sheets of paper. From the forum, members said you want it as close as possible without touching.
At idle should the SC pulley spin independently from the supercharger or just be able to spin independently by hand?
did you get shims (thin round metal to put between) with your pulley?just leave a small gap. It will also change after you have driven a while. mount it, 0.2mm all around, test it. take a look. if bad, re install , if good. Smile :d
