chisler29
Mine did that with the red crossfire. they will dry out if you keep the lights on. there is a kit you can buy that plugs the access holes better, the real "fix" is to get 99% pure alcohol and clean it out with that then seal them with the new kit, but the alcohol is EXPENSIVE.
Yeah I read that on here...I think I read everything on here! Ugh...I'm pretty sure this has already had the update kit. The little T shaped tubes are not on the back...they now have small caps or plugs. And the rubber dust caps...one on each side has a cover with a rectangular membrane of some sort about 1" X 2".
I'm just going to have to watch it a while. Wish I had garage.
