Old Mar 22, 2013 | 12:58 PM
JeffS's Avatar
JeffS
Default Brake and Clutch System
Could anyone confirm how the clutch/braking system is integraded in these cars. (if at all)
My clutch and brake pedals both feel a bit off. Pressing the brakes firmly or holding with hard pressure causes the pedal to bottom out.
Also the clutch pedal engagement does not seem consistant sometimes it grabs down low but usually its a lot higher.
Is the clutch system hydraulic, if so is it on the same resevoir?
Does this sound like a brake master issue, or perhaps the clutch issue is unrelated?
2006 xf base, 6speed manual
Thanks in advance.
