Thread: Help please.
Old Mar 24, 2013 | 06:13 PM
TopHydraulics's Avatar
TopHydraulics
Sponsor
Thumbs up Replacing and upgrading the seals in Crossfire hydraulic cylinders
Originally Posted by ZERACER
Where might you find replacement hydraulic cylinders' seals and what are the part numbers? Is this something someone could do themselves or would a shop have to do it?
ZERACER,
If you look at the attached photo, you might recognize that the seal upgrade is not a DIY job. The cylinders are crimped, and the seals are not available off the shelf. There are several seals inside these cylinders that are made of Polyurethane, and they all need to be replaced/upgraded. If you buy new cylinders, you will pay a lot more and end up getting the same problem again in some ten years or less.
Klaus
Last edited by TopHydraulics; Mar 24, 2013 at 06:19 PM. Reason: removing reference
