amx1397
do you have ball or taper lug bolts and do you have ball or taper wheels lugs holes.first make sure they match,,
if the noise is very little, you can grind off the end of the bolt,(just don't get the lug bolts hot,(too hot to hold is too hot) .so grind a little ,go to the nex lug ,keep going around until all are ground down enough to clear.
just so you know the thd part of the lug bolt should stick through the rim 5/8" jim
I have conical bolts which i guess are the same as tapered. I dont know if the wheels match. Im gonna have to find out now. The bolt thread length is 24mm so I ordered some 23mm length bolts to see if that will work. Its not much of a difference so Im not sure. I couldnt find anything shorter than 23mm. Thanks for posting
