Old Apr 11, 2013 | 08:40 AM
hallfleming's Avatar
hallfleming
Default Re: 4 Eurocharged pulleys later and I'm still shredding belts. Help?
Your tag shows code 3 pulleys. From what I understand, the later batch is a different design correct?
Originally Posted by oledoc2u
I have a 65 on the roadster and a 62 on the coupe. Coupe has been ran about 200 miles with no problems. The roadster has 5k on the 65 no belt ware. I have 1 shim on the 65 none on the 62. You have an alignment problem as we all know something has changed. may be shimmed wrong or ???
