Old Apr 11, 2013 | 02:59 PM
onehundred80
Default Re: 4 Eurocharged pulleys later and I'm still shredding belts. Help?
Very interesting that it has taken this long to be noticed. To my knowledge this has never been an issue.
How subtle is subtle. We know the OEM shim sizes can vary a little and we know the OEM pulley, SC and magnetic clutch stay the same part numbers. So I say BULL **** on the subtle changes. The pulleys are not accurately made and/or they are poorly designed.
The shim sizes change to balance the OEM build up of tolerances, The after market ones should fit your SC with only a minimal if any change in the shim size your OEM pulley takes.
If you cannot reverse engineer a pulley using an OEM pulley you measure you should not attempt to do it.
If you cannot make a pulley that is within .005" of the OEM bearing to clutch face dimension you lack the skills or knowledge to tackle the task.
