rcompart
The C-Class uses a different type of drive authorization and the ECUs are physically different between the two cars even though they are both controlling the same engine.
Are you referring to the E.I.S. (Electronic Ignition System)? So because of the different key the entire ECU had to be changed... which probably has more to do with the immobilizer...
