04Fire
Junk Yard???
The problem with that route is getting the car to Beckmann. They have to do tests in there building with the car on and started.
rcompart
The C-Class uses a different type of drive authorization and the ECUs are physically different between the two cars even though they are both controlling the same engine.
Yeah, the thing with Beckmann's idea is capturing the data between the SAM and ECU from the clutch signal(s). The ECU itself wont be needed or matter. Just the data going to it.
04Fire
Are you referring to the E.I.S. (Electronic Ignition System)? So because of the different key the entire ECU had to be changed... which probably has more to do with the immobilizer...
The immobilizer is everything, unless you can manipulate it then you can't get a factory setup. There will always be something missing. The V8 ECU is needed for the drivers to the injectors, coils and mapping etc..
