Old Apr 17, 2013 | 03:20 AM
onehundred80
Default Re: Driver Door won't lock
Originally Posted by Jamerian
motors?
i believe there are no motors. most german made cars from this era use vacuum. the yellow tube is a vacuum line that comes from a unit called "central locking pump" that is located in the rear of the car. It is a vacuum pump that actuates levers in the 3 doors. line may be ruptured if you hear hissing. can you push the lock button down with your finger?.. if not.. the vehicle may "think" your door is open.
I use the term motor in the general form.
