Driver Door won't lock
Old Apr 12, 2013 | 01:30 PM
scomer88's Avatar
Default Driver Door won't lock
Hello All,
My driver door will not lock, when i click the lock button on the console i hear like an air noise/lock motor i dk, but it will not lock. (And yes my door is closed) Anyone have this happen to them/know how to fix this. Any help is appreciated since i can no longer lock my car on the driver's side.
Thanks
Old Apr 12, 2013 | 02:09 PM
Default Re: Driver Door wont lock
Originally Posted by scomer88
Hello All,
Thanks
Maybe the motor at that door is busted or the air line is broken. Where do you hear the hiss coming from?
When you lock that door with the key do all the other locks operate?
Old Apr 12, 2013 | 02:12 PM
scomer88's Avatar
I hear the hiss coming from what sounds like where the actual lock **** is(or right under it) when i use the key and the console button all other locks work correctly. Would i need to open the door panel. If so can someone link me a how to? thanks.
Old Apr 12, 2013 | 02:37 PM
Here is a view inside the door panel. This is the passenger side but they are the same.
The yellow hose goes to the lock motor.
How to remove the door panel. (click)
Old Apr 12, 2013 | 02:40 PM
scomer88's Avatar
what should i be looking for when i open the door up?
Old Apr 12, 2013 | 06:22 PM
A broken or disconnected line or a faulty motor.
Old Apr 17, 2013 | 12:01 AM
Jamerian's Avatar
Default Re: Driver Door won't lock
motors?
i believe there are no motors. most german made cars from this era use vacuum. the yellow tube is a vacuum line that comes from a unit called "central locking pump" that is located in the rear of the car. It is a vacuum pump that actuates levers in the 3 doors. line may be ruptured if you hear hissing. can you push the lock button down with your finger?.. if not.. the vehicle may "think" your door is open.
Old Apr 17, 2013 | 03:20 AM
Originally Posted by Jamerian
motors?
I use the term motor in the general form.
Old May 20, 2013 | 06:45 PM
amatxcrossfire's Avatar
I have the same problem wont' lock, but it will unlock
Old May 20, 2013 | 06:53 PM
I can only guess that the air pressure or vacuum that operates the 'motor' can overcome the losses due to a small rupture in the line when unlocking only.
It would be nice if scomer88 let us know his outcome, maybe we will never know though.
Old May 9, 2017 | 05:39 AM
electroryan's Avatar
I have exactly the same issue. i tried to unclip the air line off the door motor and it broke the clip off. With the finger over the tube it makes no hissing noise so it has to be a problem with the lock
Old May 9, 2017 | 07:48 AM
NZ, a country I have a great fascination for, great people, great trout fishing you have it all. For the price of an air fare I'll have a look at your problem.
I am not sure what you actually mean though, can you feel any pressure or suction in the yellow hose?
Old May 12, 2017 | 07:10 AM
It seems rather like Canada in many ways ( after my recent travels ) . Theres a actual problem with the drivers door lock mechanism leaking air. with the air tube removed the system works but the door will unlock but not lock. Is there any way to rebuild it, put new seals in it etc.
Old Dec 16, 2022 | 08:25 PM
Jwit6000's Avatar
It seems drivers side door latch vacuum lock failure is pretty common. And you cant get new replacements though right hand units from scrap yards are pretty common. Has anyone figured out how to re build the left side latch to restore vacuum funtionality?
Old Dec 17, 2022 | 08:53 AM
I've seen various reasons why the drivers door lock isn't working. Quite a few of the problems was the air line being damaged/cracked to the point where the vacuum pump 'signal' doesn't have the oomph to operate the locking mechanism. Are you quite sure the lock/unlock assembly is the failure point?
pioneer4x4
Jul 27, 2015 02:04 PM
axnguyen
Jul 21, 2015 11:41 AM
55chevy
Jul 20, 2015 03:08 PM
66L72M21
Jul 15, 2015 04:23 PM
2005 Ragtop
Jul 9, 2015 03:16 PM
