If you hop over to the TSB and Documentation section, you will find almost every how to you could need. They also have the factory repair manual for downlod here:
https://www.crossfireforum.org/forum...ollection.html
Just curious, how much general car work have you done before?
- The spark plug boot can be a little tricky to remove if you are new to car maintenance. I'd skip this for now.
- The fuel filter is under a plastic cover held on with 3-10mm plactic nuts. Pretty easy to remove, however one of them needs about a 12" extension on the socket.
- Disreguard on the TB /vacumm line question. I was confusing that with another problem.
- A bad gas cap seal can cause issues also. Just pop the cap and make sure the rubber seal looks ok.
