dom03
I took the car to a auto shop and got the battery condition check. Result came back with "Replace Battery"
I replaced the battery with a top end expensive one with I think 780CCA.
Car still will exhibit the same issue in the video above where the car WILL crank but then revs drop and die, unless I accelerate alot during startup.
Driving the car I feel it has a little more response overall when gunning it! but maybe thats just my head playing tricks coz of the new batt but I honestly feel like its more responsive.
Anyway took it to my mechanic and pulled the following codes:
P0446
P20D4
P0101
P0102
P0453
P203B
He said most likely a lot of them are a result of one going bad, the rest pull up codes until that one part is fixed.
P0101 is a code I had pop up before, it's for the MAF sensor. I cleaned mine off using MAF cleaner and also cleaned out the throttle body while I was at it. Took maybe 30 minutes overall. Did a throttle reset when I was done and it worked well enough until I could get a new MAF sensor for me to swap out this weekend. Also while I was at it, I convinced the wife I needed the 74mm throttle body as well!
