Old Apr 20, 2013 | 09:51 PM
rcompart's Avatar
rcompart
Default Re: How can I disable the TPMS? (Tire Pressure Monitoing System)
Originally Posted by zalsaigh
Hello Rudy:
I would like to ask you regarding the TPM. I am trying todisable it, I took the doom light out and I saw the white connector. I removedthe connector and found out that it has only 5 fine wires with different colors,there is no 6th slot. I remember you said that the connector has 6slots. Am I looking at the right connector? I could not find another connectorsimilar to it, the only thing there, is a black box which is the garage dooropener. My XF is 04 and it may have different connector than the other models.Do you have any thoughts if I am looking at the right one? If so, shall Idisconnect the second wire colored grey with yellow stripe? Thank you for yourhelp.
The connector you're looking for is a few inches away from the one that actually plugs into the TPMS. It's going to be wrapped with grey foam. That's the one you need to get to.
Good luck and take care
