axcelr8
I just brought the car out of the garage and Eurocharge Tune and it preformed very well until it warmed up. Once it warmed up it does the same thing it did before. I changed the I/C pump "Bosch 0392022010" and coolant before I parked for the winter. Just tuned it and it's power out put is still unpredictable. Sometimes it goes like a Bat out of &@!%^ and sometimes not. Should I try changing the I/C pump again or are there other possible solutions? If I do not reply after April 22 it is because I'm on vacation till the 17 of May at which time I'm going to troubleshoot this problem.
Wire up a couple of idiot lights :
1. common ground.
2. one lead to the hot side of the S/C clutch
3. other lead to the hot side of the I/C pump.
use the windshield wiper to clamp the lights.
use different color 12v bulbs.
Then when it stumbles, you'll know what's what.
