Old Apr 21, 2013 | 02:23 PM
  #555 (permalink)
Moham_us's Avatar
Moham_us
Default re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Hi girlcrushcar
well , it was a mistake that i followed the instruction in the forum to the letter , everything is great in the instructions but no one told my that the ignition is two parts (the black cylinder key and the ignition where the black cylinder goes into)
my wheel was luck and the key was not turning (and here is the missing part) i just needed the black cylinder key (the document said if the key is not turning you have to drill the pin ) ) after drilling and taking everything out i notice that the problem was on the black cylinder means that i should order a new key 270$ , but by drilling i damaged the ignition and by the way the ignition in the dealer cost 520$ but in Mercedes 180$
the best is to check the Cylinder black key part and then the ignition if you need any help let me know i did the fix my self
and thanks for the replay
