Old Apr 21, 2013 | 09:11 PM
zalsaigh's Avatar
zalsaigh
Default Re: How can I disable the TPMS? (Tire Pressure Monitoing System)
Originally Posted by rcompart
The connector you're looking for is a few inches away from the one that actually plugs into the TPMS. It's going to be wrapped with grey foam. That's the one you need to get to.
Good luck and take care
Thank you Rudy, I found it. After disconnect the connector,there is a piece of white plastic cap holding all the lines in. If you removethe plastic cap, the lines will come out without using the pick. I hope thishelps.
