Old Apr 22, 2013 | 04:27 PM
onehundred80
Default Re: How much Transmission Fluid needed to replace after filter change
Originally Posted by Rubchris527
I have a 2005 XF w/about 70K. I need to know how much Transmission Fluid should normally be in the pan when changing filter only. I've had the car since 2007 (bought used w/20K) I had not changed or checked ATF/filter. Drained the oil. Measured and had not quite 3 qts in pan. I know there should be 8 qts total, but since not all drains, I'm wondering "how low" can I guestimate I was with the 3>qts that came out?
I will probably end up buying a dipstick to be accurate, but in these tough economic times, any input/advice would be helpful
You do not need to buy a dipstick, the forum has the answer to this problem. I use a hose from the top sider I use for oil changes and others use a plastic tie as described by Woody Waldig. Basically anything will do as long as it goes down the tube on the transmission and keeps the true oil level showing.
Click here for Woodys solution.
