zalsaigh
This is an up-date regarding the battery drain. Fuse # 9 is responsible for a drain of an additional 20 mA. Here are my findings: With fuse#9 in its place and doors are unlocked, the drain is 65 mA. The drain is reduced to 55 mA when doors are locked. When fuse #9 is removed, the drain is reduced to 45mA when doors are unlocked and 32mA when doors are locked. It is obvious that the door lock and security system are causing a drain of an additional 20mA. It is also obvious that the door locks have something to do with the drain. The car drives normally with fuse #9 removed, except that the remote locking is disabled, it has to be done manually. Any thoughts about finding the fault in the doors will be appreciated. Is the rear door has anything to do with the drain?
I would check the trunk. Passenger side in the fender for water and a potential bad ground. Also check the glovebox switch as there have been a few cases of intermittent behavior and it is tied into that same circuit
