Battery Drain Problem
Apr 23, 2013 | 08:57 PM
30
permalink
zalsaigh
Aug 2009
39
Grand Island, NY
Re: Up-date, Battery Drain Problem
Quote:
Infinity
I would check the trunk. Passenger side in the fender for water and a potential bad ground. Also check the glovebox switch as there have been a few cases of intermittent behavior and it is tied into that same circuit
Do you know what to check in the trunk? Is there a switch or wires need to be inspected? I removed the bulb from the light housing which did not help. Recently, I had the right fender drain cleaned and the negative cable between the battery and the fender removed cleaned and installed. Do you know any other ground connection in that area needs to be checked out? Is any connection(s) at the cowl under the plastic cover that may be related? Any help is very much appreciated.
zalsaigh
View Public Profile
Send a private message to zalsaigh
Find all posts by zalsaigh
