Old Apr 23, 2013 | 09:16 PM
Infinity's Avatar
Infinity
Default Re: Up-date, Battery Drain Problem
Originally Posted by zalsaigh
Do you know what to check in the trunk? Is there a switch or wires need to be inspected? I removed the bulb from the light housing which did not help. Recently, I had the right fender drain cleaned and the negative cable between the battery and the fender removed cleaned and installed. Do you know any other ground connection in that area needs to be checked out? Is any connection(s) at the cowl under the plastic cover that may be related? Any help is very much appreciated.
Engine to chassis ground is located at the transmission bell housing on the driver side.
Passenger side trunk you will see a foam wrapped box that is the central locking pump and alarm module. There are a few hounds back there. Brown wires bolted to body.
