Re: HID in high beams
If you were creative enough.. couple relays.. some spade ends.. run leads from lows connector to high bulbs (becomes DRL in high beam position in headlight) with relay - normally closed. Add HID to low beam position fed by high beam circuit which also would be wired to open high beam DRL circuit on the relay. Your high beams would be normal H7 bulbs but you wouldn't have the lows on with it. Makes sense in my head.. LOL.
