onehundred80
I do not have one for sale. What makes you think it is the RCM?
Explain the symptoms and we may be able to help.
Symptoms this afternoon: Wife calls and says no start. I arrive and all power items work, windows, lights on dash etc. - key turns but no crank - no clicking like dead battery or solinoid on starter deploying.
Went back to work and read forums - sounds like possible RCM based on forum. I go back to car after work and take cover off of the RCM and tap the top area of the fuses on the RCM and get wife to turn Key. Car starts right away. Drive car home - park in driveway, try again to start and fires right up again.
Assuming it's the RCM issue so will take it out on the week-end and have a look at the connections with a magnifying glass & most likely take to somewhere local to soldier if it's got the cracked soldier joints.
I will also check to ensure no loose nuts like on splice block 100 as per anothr post I saw.
Thanks,
Steve
