Old Apr 28, 2013 | 09:33 PM
oledoc2u
Default Re: Crossfire won't start
Originally Posted by oledoc2u
You got tires and your car wouldn't start after the tire install and no problems before this? You sure that battery has cranking amps? A battery can show charge and still not have enough cranking amps. Check connections and ground wire as mentioned above.
Did you have any problems before the tire install?
