JHM2K
Perhaps I should have clarified more... the pics from Brian's thread are indeed ones of a resonator delete... but if you look closely, there are two connector flanges right after the cats, THEN you see the H-Pipe (post cats). Rob's downpipes are set up to use factory connection points IIRC... so the assembly should simply swap out with the OEM mid-section w/ cats. Therefore, the H-pipe would be in place to equalize flow. No "need" for an X-pipe.
Doh! I see where you're goin now. My problem with the X pipe is what size of pipe. Brian shows a Y pipe with 2-3/4" size. Yet all I'm able to find is mainly 2-1/4, 2-1/2 & 3" Xs from Magnaflow, Duramax and others. I even asked in a separate thread whether anyone could give me the p/n to the one they have used with only vague responses about what others thought were being used. But never any definite answers.
I'm not worried so much about the cost as I am about the quality/workmanship of the part. Seen them running from $25 to over $100.
