Old May 1, 2013 | 07:20 AM
Mrmiata's Avatar
Mrmiata
Default Re: How can I determine what audio system my car was built with?
MrMouth, your logic is deplorable. The presence or absence of an antenna proves nothing, think about it.
The only real proof that a nav radio was fitted is if the two extra wires that were added are there still there, as no one would bother to remove them, but they could remove the antenna as it has value.
You do not have a nav radio, you have not installed a nav radio, and you know nothing about how to do it.
Olady .. think about it. IF there is a Nav antenna left in place.. It wasn't because someone couldn't find the readily available thread to finish the install which I have read but know nothing about.
You always have a hard time accepting YOUR not the final authority on things?
I guess the presence of an antenna just means the deal fell through on Ebay for the HU..
Or squeeze this between your ears.. NAV unit was removed.. owner didn't want to jack with removing the antenna.. WOW WHAT A CONCEPT!
Need to type that slower so you can follow along?
