Old May 3, 2013 | 02:01 PM
ala_xfire
Default Re: Help - PLEASE 😥
Sounds like water in the hatch.
To check :
1. put the top up.
2. move the divider to the top up position.
3. remove the center rear boot trim
4. remove the right side trim panel.
5. flip up the bottom panel and remove the foam on the right side.
6. the locking pump is encased in a foam block which might be water soaked.
7. dry everything out, then find and fix the leak.
