Help - PLEASE 😥
Old May 3, 2013 | 01:18 PM
CB20's Avatar
Exclamation Help - PLEASE 😥
ALL light flash, alarm goes off, hazards flash and car stalls - mid drive!! I lose power steering and power assisted breaking - not good at speed in the outside lane of the M25.
I am then unable to re-start unless I get out, lock and unlock with the remote locking and it then starts - I drive for 10 minutes then the whole sorry story starts again - all dash-board/warning lights flash and then stall.
Chrysler has run all diagnostic tests and found nothing.
PLEASE help - its dangerous
Old May 3, 2013 | 01:57 PM
grip grip's Avatar
Default Re: Help - PLEASE 😥
Sounds like water in the hatch.
https://www.crossfireforum.org/forum...f-driving.html
Old May 3, 2013 | 02:01 PM
To check :
1. put the top up.
2. move the divider to the top up position.
3. remove the center rear boot trim
4. remove the right side trim panel.
5. flip up the bottom panel and remove the foam on the right side.
6. the locking pump is encased in a foam block which might be water soaked.
7. dry everything out, then find and fix the leak.
