Old May 5, 2013 | 01:16 PM
onehundred80
Default Re: Light out Indicator
Originally Posted by gehoben
Recently my light out indicator on the dash came on
It comes on whether or not the lights are on or off
I checked and it seems All the bulbs are working
I checked every bulbside indicators headlights taillights everything
Any suggestions?
From the Owners Manual
11. Light Outage Indicator
With the key in the ignition switch turned to
the ON/RUN position, an indicator light
comes on. It should go out when the engine
is running. If the indicator light does not go
out after starting the engine, or if it comes on while
driving, it indicates a failure in the parking light,
taillight, stoplight, or low beam headlight.
The indicator light will come on when the exterior light
fails. If a brake light fails, the light outage indicator will
come on when applying the brake and stays on until the
engine is turned off.
This does not mention the two license plate lights, and the light works for these as well.
