Old May 9, 2013 | 06:12 PM
  #57 (permalink)
onehundred80
Default Re: P0410 code check engine light
Originally Posted by kragath
I remember having that problem on my Crossie on last summer, but light went off after clearing fault codes with OBD reader. AND NOW IT'S ON AGAIN!
Manual said that reason for light coming on could be low quality fuel or gas tanks cap... yeah right!?...
Is the RCM located next to car battery and do I have to find RCM directly for 05' model or do all models use same RCM?
Do not panic and buy a RCM, not yet anyway, read this thread and see the possible causes of the light on condition.
You can inspect the RCM to see if the relay for the pump has burnt contacts on welded contacts.
Do you hear the air pump work? That is the first question to answer.
The RCM is in the box by the battery, it is the module with the fuses on it. The forty amp fuse is for the air pump.
See this thread as well.
