Old May 17, 2013 | 08:11 PM
Parallel Ice's Avatar
Parallel Ice
Default Re: Fuel Pump Relay Project - We can rebuild him
Originally Posted by alaxfire
The K40 Relay Control Module has SPST relays, not solid state.
There are 5 of them on the board, soldered, not plugin.
The main problem with the relays themselves is the Air Pump relay ( #5 ). It feeds power from the 40 amp fuse to the air pump on the front of the engine at initial startup for approx 30 seconds. The contacts on this relay tend to burn much faster due to the higher amp load.
I ordered, and received 12 of these relays, but found it very hard to remove the old relays from the board, so after successfully replacing only the #5 relay on my spare board, I gave up.
The problem with the board itself is the 3 solder points originally addressed, I'm not sure if the issue exists due to mechanical vibration, or fluctuating temperatures.
See this thread for pictures of the relays, as well as the 3 solder points on the board :
https://www.crossfireforum.org/forum...u140-code.html
THANK YOU! You have shed a LOT of light on this. Reading through what you have shown, there seems to be quite a few opportunities here for improvement, most of which are outlined really well on here.
This thread may be entirely useless, but I will update as I modify (re-solder, shield, horny, anything else).
Thank again and cheers!
