Old May 19, 2013 | 09:34 PM
SrWilliams's Avatar
SrWilliams
Default Re: Replacing exterior door handle
Originally Posted by Infinity
Stop you don't need to pull the door panel to get the handle off.
Pull back the weather stripping on the door and you will find a hole that lines up with the hex screw that holds the handle on. If I remember its 5mm. remove screw and make sure you use a magnet on the hex key to pull it through the door. This will undo the right most part of the handle and then the large portion tils out
I too want to remove door handles. CAn you lay this out a little more as I am so afraid to mess something up.
