Thread: A bit confused?
Old May 22, 2013 | 07:42 PM
+fireamx's Avatar
+fireamx
Default Re: A bit cofused?
Originally Posted by Ed Mahoney
well I heard that all 04 had all the options so they where really a limited ! After 04 they started to make a cheaper one so if ya wanted everything the 04 had you had to buy a limited !!! So in a way the 04 are a limited in that they had all the options !!! Yes ?
No, when it comes to cars, the term "Limited" usually denotes something more "exclusive" than a Standard, or a Base model.
For the 2004 model year, there was only one model manufactured, so using the term Limited makes no sense, and you won't find it anywhere in the 2004 Dealer Promotional literature, or found on the factory MSO document.
Referring to an 04 as a Limited, is just as wrong as calling the red SE convertibles, the black Base models, and any SRT models a Limited.
If anybody here on the forum has an "Original" 2004 title that says "Limited" on it, then it was a mistake the Dealer made when you purchased your car, and I would bet the confusion happened because the 04 was purchased AFTER the 05 models made their debut.
As Rayth pointed out, "What's in a name"? Well let's put it this way.
If somebody has a 69 SS Camaro Rally Sport, and you refer to it as just an SS Camaro, I'm guessing you would probably hear about it.
