AKING57
I accidentally pushed my mirror adjusting control **** and it popped out of its fixing and fell through the center console.
My question is how do I remove the center console panel with the cup holder and mirror adjuster (or at least where it should be) so that I can push the mirror adjusting switch back into place. I assume the panel just clips in , but don't want to force it in case I crack the plastic.
Any ideas please
Andy
Here are some pictures that I took when I replaced the cup holder, hope it helps. The parking brake handle cover comes off first, it can be very difficult sometimes might need some lube to help WD40 or your choice. then the part around the shifter, It snaps off, be careful prying with something non marking. Then the screws front and back. It really is easier than it sounds.
