How to remove mirror switch center console panel
Old May 22, 2013 | 08:06 PM
AKING57's Avatar
Default How to remove mirror switch center console panel
I accidentally pushed my mirror adjusting control **** and it popped out of its fixing and fell through the center console.
My question is how do I remove the center console panel with the cup holder and mirror adjuster (or at least where it should be) so that I can push the mirror adjusting switch back into place. I assume the panel just clips in , but don't want to force it in case I crack the plastic.
Any ideas please
Andy
Old May 22, 2013 | 08:19 PM
Larry Hitze's Avatar
Default Re: How to remove mirror switch center console panel
Any ideas please
Andy
Here are some pictures that I took when I replaced the cup holder, hope it helps. The parking brake handle cover comes off first, it can be very difficult sometimes might need some lube to help WD40 or your choice. then the part around the shifter, It snaps off, be careful prying with something non marking. Then the screws front and back. It really is easier than it sounds.
Old May 22, 2013 | 08:43 PM
AKING57's Avatar
Thanks so much for the quick reply, looks fairly easy will try it this weekend
Thanks
Andy
Old May 22, 2013 | 08:44 PM
If you need more reference material I believe that you can find the repair manual here on the forum, download it.
https://www.crossfireforum.org/forum...e-bin-how.html
here's the link for the service manual download it for future reference! It is for the coupe but it is mostly the same except for the top.
http://api.viglink.com/api/click?for...13692702023887
Old May 22, 2013 | 09:11 PM
Here's a PDF with words and pictures. (click)
Shows how to lift those trim panels.
pioneer4x4
Oct 6, 2018 01:09 AM
rocketrage
Oct 7, 2015 05:00 PM
mattnelson71
Jul 28, 2015 12:52 PM
MissSilky
Jul 22, 2015 04:28 AM
Rjono
Jul 15, 2015 03:29 PM
