Old Jun 1, 2013 | 02:23 PM
whoosh's Avatar
whoosh
Default Re: Help with Misfire issues
You might have picked up some crap from your fuel and it has impeded the flow through some of your injectors. It is allowing enough fuel to run good to a certain rpm but can't supply enough for higher rpm's. It may also explain the occasional time when it clears up. I just got my crossfire so my knowledge of the car is very limited at this point. As far as the timing jumping, I think it would run poorly under 3k also.
