MrMoPar
If you cracked the oil pan, you better be checking the sway bar, lower suspension, and crossmember as you have to get through them plus the belly pan to get to the oil pan. Also check that upper pan as they are so easy to break.
From visually inspecting I see no other damage... After hitting the middle rural divider the plastic shield broke away n all I see are pieces from the bottom oil pan. I reached around and couldn't visually see any other damage....
